1g 6bolt build
talonkid93
64
Dec 16, 2007
bayonne, New Jersey
Whats up everyone i finally bought another talon and I am slowly building it up parts i have laying around so far are , AEM EMS, AMS DSM External Oil Cooler Kit, KOYO Performance Lightweight Aluminum Radiator, HKS DSM 4G63 Cam Gears, HKS DSM 272 Camshafts,
HKS Super Sequential Blowoff Valve, AMS DSM 6 Bolt Stroker Kit, Walbro 255 lph Fuel Pump Kit, Buschur Racing 1G FMIC Kit, 2600lb w/ 6 Puck Plate Sprung, ACT Streetlight Flywheel. Also bought arp main and head studs. I cant decide on the turbo yet and would like some opinions. My goal is around 500-600awhp. This car is only gonna be a weekend driver keep in mind. All opinions are welcome thanks guys.
very nice. from all the reading ive seen i would reconsider clutch options and probably go with a twin disk if your running that much power. what is your intentions with your turbo setup you going to use the stock manifold or do you plan to upgrade that.
Forced Performance Turbochargers has a bunch of options for turbos if your planning to run a stock style turbo setup.
What kind of fuel are you going to be using to hit your HP goal? 93? e85? C/Q16? You could get 550AWHP from a mean HX35 setup, but if your looking to make the power on pump gas, you'll need something that's a little bigger. Also, like mentioned above, what manifold are you using (DSM, T3, T4)?
its gonna be a 2.3l stroker. I wanna reach my hp goal on 93 pump gas. As for the exhaust manifold im not sure yet but i was looking at a ams gt35r kit that comes with the optional tubular manifold
If your looking to go that big... try out precisions 6262 turbo. A lot of evo guys run them and they make 650+ awhp some even in the 750hp range
