6bolt build questions
TEEJ
49
Feb 19, 2011
Richland, Washington
looking for some help on my build. i'm going with a 6bolt build with a stock crank and probably manley i beams and wiseco 9.0:1 comp pistons. 1mm oversize valves with kiggley springs and retainers, bc 280 cams, and looking at either an fp green or an fp3052 and looking to run about 25-30 psi. just wondering what injectors i need and if anybody had some input or other suggestions on what i should use or swap out for other parts. thanks.
That sounds like a similar build I am working on, I will be going with 1000 or 1200 cc injectors, probably high impedance. These should be sufficient up to 500 wheel or so as a rough estimate.
i'm only shooting for the 500awhp range. maybe 600awhp if they can tune it on my build but it's doubtful. so you think that 1000cc would be enough?
Depending if your running e85 or pump gas. Pump gas I would say 1000's should do it but the 1200's would probably be safer. I use 880's at 23 psi on a 50 trim and still have some room to grow with the cycle duty.
i plan on running pure premium with an octane booster. nowhere to get e85 around me. so the best octane i can get and 1000cc injectors around 25psi and i'll be good? and 1200cc with 30 psi?
There are so many variables that would effect how your fuel will work out, but if you can get 1200cc for the same price as 1000cc which is likely, it may be best to go that route. There is no way to say for sure, but I do believe 1000cc will achieve what you are shooting for.
alrighty. thanks for the help guys. anyone got any comments or concerns about the build or suggestions for it? any advice or criticism is well taken.
