BadIrene69
- 0
- Mar 20, 2022
Phoenix,
Arizona
I recently inherited a 1999 spyder gs (2.4L 4g64 SOHC) with the 5 speed manual trans. The car sat untouched in a garage for about 8 years before It came to me. Here's a break down of what I have done so far:
Before trying to start it:
Replaced: oil, oil filter, coolant, trans oil, break fluid, clutch fluid, power steering fluid, spark plugs, spark plug wires, battery, fuel pump, siphoned old gas, replaced with new gas. Gave each cylinder a shot of fogging oil knowing they were likely bone dry.
At this point I tried to start it, the car cranks but would not turn over. I noticed that cylinder 4 was getting some oil around the spark plug so I decided do a compression test, every cylinder came back within 8-10psi of each other. Decided to replace the valve cover gasket and spark plug gaskets. I inspected the timing belt, still looks like it is in fine condition, and is under tension. Cranked again, this time it sounded like maybe 1 cylinder fired then it died. Only cranks after that.
Unsure of exactly where to go from here. From what I have been able to find online sounds like it could be an issue with the fuel pump relay? Ive seen suggestions to bypass, but I have had a hard time locating it on the 2.4L spyder. When I replaced the fuel pump and hanger, the replacement pump did not come with a hole for the fuel tank pressure sensor, could this be the issue? I also tried the screwdriver trick to check the injectors, kind of difficult to tell over the engine cranking noise, but it sounds like they are all ticking. Lastly, when I turn the key to the on position, I get a short "buzz" sound from around the intake manifold, might be totally innocuous but I figured I would throw that out there.
Any suggestions on where or what to check next??
