Spyder 1998 Spyder GS - Driver Rear Quarter Window Went Down, Now Completely Dead.
sirhecker
Jul 22, 2026
Victoria, BC, Canada
Hey everyone,
I’m new to the DSM community and currently restoring a 1998 Mitsubishi Eclipse Spyder GS. I’ve been slowly bringing the car back after it sat for quite a while and have already fixed several electrical issues.
My biggest issue right now is the driver-side rear quarter window.
Here’s exactly what’s happening:
  • Driver rear quarter window went down normally using the driver master window switch.
  • Now it will not go back up.
  • Pressing the switch UP is completely silent. No click, no motor noise, nothing.
  • The window is now fully buried inside the quarter panel, so I can’t grab the glass to pull it up manually.
  • Rear seats and interior trim are already removed.
  • I removed the rear speaker and found the access holes behind it, but I still can’t actually reach or see the regulator because it’s hidden behind the inner body structure.
  • I also found what appears to be the larger Spyder control module behind the rear seat (black box with blue and white stickers), but I haven’t replaced anything yet.
Other window behavior:
  • Driver front window works.
  • Passenger rear quarter window works.
  • Passenger front window currently does not work, but that’s a secondary issue and my priority right now is getting the driver rear quarter window closed before I continue troubleshooting.
My questions are:
  1. Has anyone had a rear quarter window that would go down but then become completely dead on the UP command?
  2. Is this more commonly a master switch issue, the Spyder control module, wiring, or the regulator/motor?
  3. Most importantly, is there a way to manually raise the rear quarter window while I diagnose the electrical problem? I’d like to get the glass closed to protect the interior.
Any advice, service manual references, or photos of the regulator/access points would be greatly appreciated. Thanks!
  • Wanted PASSENGER DOOR LOWER MOLDING
    WANTED
    • LA_gst
  • For sale 2g 2g 1999 eclipse gs-t spyder
    Very clean 2g spyder, only modifications is 14b turbo with 3inch exhaust. Well maintained and...
    • DSM B
  • For sale 2g 1996 Talon TSI AWD
    1996 Talon TSI AWD $10,500- 90,421 miles ( will go up a little ) - clean title in hand -...
  • For sale 2g 2g power window motors. OEM
    RH and LH power window motors. OEM $40 each or $70 for the pair. Message 702-741-6987.
  • Wanted WTB 268 Camshafts & Zero Tick Lifters
    Looking to see if anyone has a set of 268 cams in drop-in condition. I know 268 is on the Rare...
    • Ice9
