1998 rs 5 speed swap.
TunerMike
Sep 15, 2012
jacksonville, Florida
Alright guy's im new to the forum no i don't own a eclipse. But im about to do a swap for a buddy. I helped my dad out on his 5 speed swap. As well as a 240sx. I am going to tackle a job of my own for a 5 speed swap.
Basically i need help on parts im going to need. If i leave anything out please let me know.
-transmission
-cables
-shift assembly
-clutch pedal
-Ecu?
-clutch slave cylinder
-master cylinder
-wiring to trick the Ecu.
I know there is a few more parts but that is why im on this site for help.
let me know what other parts i need not looking for websites just the part i will do the research on them
Thanx ANYONE AND EVERYONE :D
Mike.
Also we have found a 95 talon will this transmission swap over to the 98 rs?
Help would be greatly obliged :thumb:
can i use the clutch pedal assembly/shifter lines/cylinders/etc off this car as well?
you will also need to swap the brake pedal as well. and the 420a requires some cutting in the firewall for the master cylinder some say its easier to remove the dash but it can be done without doing so.
On my dads we just cut the brake pedal probably end up doing the same 5 minutes of grinding problem solved ;), and we punched it through engine bay on my dads car aswell LOL..
