2G 1998 Eclipse GST auto trans problem
Fluid level, pump or converter. Check the fluid level, then pull the pan and check the filter for clogging with material if the level checks out good, remember that it gets checked in neutral, engine running.
Check fluid and its good no noise or anything, just won’t move at all
Checked filter too
