1998 Auto trans (park) problem
IT could be a number if things. It is kind of hard to tell. It would fairly easy to drop the pan and check out the linkage inside the tranny. It could be something as simple as a damaged shifter cable, something lodged in the shifter assemble, or it could be something in the tranny.
do you have any example pics cause i really don't know automatics to well and ill get more details when i pick it up monday
You would really just have to look at it and feel it out. I can't show you a picture of what might be wrong with it because there are so many random possible situations. Just pull the console. Look around the shifter, see if anything looks out of place or damaged. If not i would un hook the shifter cable and see if the shifter will shift into park with the cable un hooked. If it does than there is a problem with the cable or transmission. You can at this time un-bolt the shifter cable from the transmission and see if there are any snags in the cable and see if the linkage on the tranny will shift into park It could also be an improperly adjusted linkage on the transmission.
well i appreciate your help and ill try and PM you on monday if you don't mind
Park isn't controlled by the valve body, it is a separate linkage off the main shaft that goes to the differential
