2G 1997 Mitsubishi Eclipse GSX maintenance?
Fernando121
Oct 5, 2022
Anaheim, California
Just bought this gsx wanted to know what kinda maintenance should I do before driving the car once every week, it has Rebuilt 6bolt engine swap ,272 cams, Evo16G Turbo, 1250cc injectors, flex fuel e85,fuel lab fuel pressure reg,walbro 525 fuel pump, ECMlink tuner, stage 2 clutch, afr & voltage gauges, tein coilovers, Upgraded FMIC, brand new Duralast Gold battery, spark plugs & oil change Trans and Diff fluid just done. Money isn’t a problem just need some knowledge I’m coming from a 420a
New timing belt. Make sure the balance shaft belt also gets replaced if the balance shafts haven't been eliminated. May as well replace the water pump while you are in there. Since you have a lot of work done previous owner may have replaced the belt (probably did) but if you're not sure it can be a ticking time bomb.
+1 on the above post.
Its a 20+ year old car so check out everything that is rubber for rot.Vacuum hoses, I replaced my radiator, heater and other coolant hoses for silicone recently. Check the condition of the rubber hoses for the brake lines. Tires.
Check the turbo for play.
The pad level of the rear brakes.
