1995 GSX radiator question
MitsubishiLover1996
Dec 29, 2013
sacramento, California
Okay, my radiator just had a major leak and I'm replacing it. I wanna know if it would matter if I get a non turbo radiator. Mine is turbo but a friend told me it didn't really matter. I have that question and also if it heated up not that long ago but fixed it. Then my radiator started having a major leak, any suggestions of what else I should replace with my radiator as well?
Not sure if a n/t rad would be be compatable, but when replacing the rad check the hoses, make sure they are not hard as a rock. And actually I dont think the n/t rad will work, I think the nipples on the rad are in the wrong spots. But dont quote me on that.
A 2g n/t radiator will fit in the turbo model just fine. however, you will need to change up the rad hoses because the entry and exit spouts on the rads are in different locations.
The top pic is the 4g63t radiator, bottom (although it has a turbo) is the n/t 420a radiator.
