1995 gsx shell question
superpenguin
44
Jan 22, 2011
bradley, Illinois
I have a 1997 gst eclipse and i just found a really good deal on a 1995 gsx roller and i want to put my motor into it. my question is what all needs to be done to wire my motor into the 1995 shell? doese anyone have the swap wiring diagram for the 1995 to 1997 cas?
Just match the wire colors up to the new pigtail. As for the firing order, I believe it was 95-96 cas that inverts it.
I matched the colors up, soldered them and ran it. I didn't have to do anything with the coilpacks.
i did a 96 engine swap into my 98. I swapped the ECU and the harness so everything was the same. Definitely a lot easier IMO then trying to match wire colors.
