TJV
- 6
- Nov 3, 2016
Kensington,
Maryland
two owner car (same family), 194,000 miles, dealer serviced for 170,000 miles then I took over as an enthusiastic amateur, have all service records from day 1, many new parts but few glitches remain.
Car is all stock except for original wheels.
New parts:
Jack's Stage 1.1 AWD transmission and clutch professionally installed by Chrysler Dealership (3/2011) has approximately 15,000 miles (original transmission included with car)
Left front half shaft replaced due to boots being torn
Turbo rebuilt
Left and right ball joint arms (front) replaced
Rear wheel bearings replaced
new radiator and hoses replaced
new alternator
new battery
new brake calipers all wheels
New rotors front wheels
Spark plugs
Idle stepper motor
Throttle position sensor
Oxygen sensor
Exhaust from manifold back
Timing belt and water pump (2015)professional installation
Remaining issues
Idle surge remains, there is a vacuum leak I have not been able to trace
Brake lines leak and will need replacement, this is the reason it is not driveable!
Needs new tires
Rust developing on right front fender (will need fender replaced)
Passenger side dash cover delaminating
Head liner sagging
