1992 AWD Trans in 1990 AWD Talon
School Boy
154
4
Oct 31, 2013
Chicago, Illinois
I know this has been covered somewhere before but I could not find the thread on it. I have a manual 1990 Talon and I need to but a 1992 trans in the car. I already have a 23 spline transfer case. What else do I need to put the 92 trans in? Will my shifter and linkage still work? Sorry for the newb questions guys.
Did you put a 92 trans in a 90 car?
No I put a 93 into my 92 while using a n/t shifter base and cables and found I had the n/t bracket on for the shifter cables then got a 90 bracket and then found I only had one gear because the 90's were different then the 91+. I'm probably going to have to swap to a pure 90 setup.
NT and turbo shifter and cables are the same, just a change between 1990 and 1991 up.
Ok good to know, I didn't see a difference between them when i did compare the two but its always good to get conformation.
I was able to just change the cable bracket and the shifter arm on the trans, then I adjusted the cables on my linkage and it shifts fine.
Good to know. Ill have to find the shifter arm and the bracket.
Anyone have a 91 and up shifter arm and cable bracket they want to get rid of?? I can PayPal right away.
Quick question. So you put a 90 shifter arm and cable bracket on the 91+ trans and it was fine with the 90 cables and shifter? Which arm? There are 2 arms on the trans?
I really dont want to change my shifter and cables if i dont have to. Does anyone else have input on this?
Anyone??
The one attached with a roll pin to the shift shaft.
Yeah its the one that has the roll pin holding it to the rod that shifts the gears. I have no issues shifting at all, you may have to adjust the cables at the shifter but thats all I did and it works great. Just make sure if your car is a 90 your using the 90 shifter arm and bracket.
Thanks guys! I'll swap that arm out, find a 1990 cable bracket and then I can finally put the trans in.
