1992 1g CV Axles in Europe
Xtalex
8
Jul 25, 2023
Ohio
Both cv axle boots are broken so i bought replacement but they don't fit, the part number was right but they're too big and every other replacement we could find is the same so the only thing to do is to buy the whole axle. The only problem is that I can't find cv axles for a fwd 1g anywhere besides used from US ebay.
So i wanted to know if i can find new replacements, or at least used but from Europe
Parts order notes say to "Order by engine size & type, trans type, color code and build date." Mitsubishi used different sized axles on some FWD models and this issue has surfaced before here on the board.
The parts reference I'm using says MB926905 is the outer boot kit (MB926907 inner boot) for your car (1992, FWD, Manual, DOHC, D22A, MNHMLFJ). The axle diameter for the boot is .905". This is the same kit used on higher trim level Galants (GS, GSR, GSX, VR-4). The NAPA equivalent is Part #: CVB 6862159.
Where did you get your new boots that are too large? I'm not sure what your parts store is called in Romania but if they can look up parts by
RockAuto.com ships internationally, but I can't imagine what shipping would cost for a full axle.
For just the outer boots: Click meee
I looked it up on rockauto, 80 for both and 100 dollars for transport which is not thaaat bad so i think I'll buy the whole axle to make sure I don't run into any problems in the future. Thank you so much for the help❤️
D
Can you help me with the part number for the left and right axle as well?
