cv axles
91gsexx
Apr 7, 2013
Statesville, North Carolina
I can't gst the damn axles out I've tried a pribar and everything axle has pulled out of the boot in the tranny need help thanks
Us a good pry bar and pry so your pushing the axle out. There is a sweet spot on the circlip that you need to find so as you pry turn the axle. Once you hit the right spot it will pop out no problem.
Ya last time I did a cv axle I had a buddy with me and we just put a pry bar on each side and pushed at same time came right out. Has to be even pressure thought. I had a hard time with one pry bar byself but like said before you have to find the sweet spot.
Also have a friend try tapping on the CV cup with a hammer as you are prying on it. You may need to tap on it from a few different angles to get it.
