Resolved 1990 Mitsubishi Galant GLS steering column play
vig444
3
Sep 10, 2022
Paris, Europe
Hello, following a replacement of the steering rack by a mechanic, I have play in my steering wheel from top to bottom on my 1990 Mitsubishi Galant GLS.
I removed the horn from the steering wheel and the center bolt is tight. There is also play on the steering shaft when I move the steering wheel up and down.
When I turn the steering wheel shakes and creaks.
Can you help me identify the problem please?
The tie rods are also new.
Thank you.
Solution
Hello thank you very much for your answers, the problem has been solved it was a steering shaft bushing that was broken!
I am attaching photos of the bushing.
That does not seem like a lot of play to me- should not cause any problems, but given that it just appeared I understand it can be concerning. I bet the steering linkage was pulled tighter when it was bolted to the input shaft of the steering rack or some other intermediate joint at the factory- that linkage might have been taken apart and bolted back up with a little more slack in it. If it REALLY frustrates you, you can get under there and see if you can check all the connections and re-bolt it with the slack taken out. If it were mine I would probably just live with it.
Solution
