18x8's evo offset?
All EVO 8 and 9 wheels (even the MR BBS wheels) are 17x8 not 18x8 with a 38mm offset. Yes they fit perfectly and many members have them, just do a search or look through gallery.
EVO wheels are 17's and they do fit (I have EVO 8 wheels on my car now as do a lot of others) and mine would rub in the rear (until RRE rolled 'em with a metal pole :D) If you're talking about 18x8 aftermarket wheel meant for an evo, the width and offset I'm sure will be fine but even with the 17's there's not that much more room under there :p
yes i ment 18's WITH an evo offset...
Yes they should fit, depending on what tire you run. If you go with the nromal 225 or 235 width, you'll probably have to roll the rear fender lips abit. I run 18 x 8's with a 40 mm offset, so very similar fitment & with my 225/40/18 Kumho MX's, I had to roll the rear lips abit. If you do a little searching in this forum you will find multiple threads on this subject.
  • Wanted 6 bolt NT water pipe
    • chrisman287
