THE_ARTIST_'s Eclipse GSX
Mitsubishi Eclipse GSX
1G bored TB (63mm), 1G intake manifold, ETS Race FMIC, HX40 BEP T3 .70, REDJACK T3 manifold, FP intake pipe, Magnecore ign. wires, 1G coil pack, Tial 44mm WG, Custom 3"-4" exhaust, Hallman Boost controller, Tial BOV, JEGS -6 fuel lines & elite fittings, Walbro 255 hp pump, Fuel Lab filter & AFPR, FIC fuel rail, FIC 1450cc, K&N FIPK, Deleted Cruise & AC, E85 <--good stuff.
Mods-Engine
Ross Pistons (SOB coated .020 over), Scat Rods, Comp. Balanced 6 bolt crank, Main Girdle, ARP's, 1mm oversized Valves, Bee-MAD springs, DKS 280 cams, coated bearings, Mitsu MLS HG, Forward Facing Filter bracket, Fidanza Cam Gears, New water & oil pump, BS elminated. Built by Darren King & FFWD connection.
Mods-EMS & Logging
DSMlink V2.5, Autometer Boost, Oil press. Oil Temp & EGT Temp., NGK AFX WB o2
Mods-Drivetrain
Indigo Aluminum Flywheel, SouthBend clutch.
H&R springs, KYB adj. (rear), Rota D2 18x9 +30mm. Nitto 555 225/40
Parts Wishlist
Borg Warner S300SX 83/75 turbo, built tranny, Coil overs, SD, 10 sec time slip, And some candy.
1/8 Mile E/T
9.417
1/8 Mile MPH
75.239
Timeslip Photo Link
Timeslip Details
Track Name : Kinston Drag Strip
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : 2950
Tires : Street Radials
Altitude : ?
Sponsored Car : no
0.0 lb/ft
  • Like
Reactions: HannahGST
THE_ARTIST_
More in 2G DSM
Share this Vehicle
