18g install problems
2g4G63
Jan 16, 2004
Corona, California
I just installed the greddy 18g on my 98 GST and it pulls harder than the T-25 but i dont think its pulling as hard as it should be. I was expecting a lot more out of it. I didnt port the O2 housing, just the wastegate. Im running the same 15 psi as i did on the T-25, and using the same actuator. Have a CEL for TPS and O2. There is no shaft play on the turbo, everying is fine mechanically with it. There are no boost leaks. I dont know why its not pulling as hard as it should be, please help. my mods are:
Apexi GT downpipe with N1 exhaust
FMIC with upper piping
Type S BOV
hacked 3" injen intake
SAFC
Walbro fuel pump
If anyone has any ideas why its not pulling like it should please post! thanks in advance.
2g4G63 said:
shouldnt even 10psi on a 18g pull much harder than 15psi on the T-25?
Pressure is measured at the intake manifold so 10 psi is the same for both turbos. The advantage of the 18G will become more apparent at higher psi and rpm where you're reaching the limits of the T25. The 18G will also allow you to run 20+psi when you're ready. If you only plan to run 10 psi, you'll be better off with the T25 because of quicker spool.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
