17 psi Wastegate Actuator & NO boost controller?
miden
215
5
Apr 8, 2003
Fort Collins, Colorado
So I'm planning my future mods for the days when I have more money than sense. I'm not looking for a 400 whp monster; just an above average, reliable street machine. I'm thinking about a FP big 28, exhaust, intake, the usual monitoring tools, fuel managment, clutch, etc, etc, etc...
My question is that if I'm not looking for a super high power ride and I decide that 17 psi. is good, will the FP 17 lb. WGA and no boost controller give me 17 lbs. or boost after the spike? I figure it should but want second opinions...
thanks y'all...
-M
Yes if my thinking is right, I am sort of learning all this type of stuff too. A boost controller is a vein that relieves pressure from the wastegate allowing it to stay shut longer or build more boost. Correct me if I'm wrong here guys... :)
400 WHP on a T28 is probably going to be tuff to do.
You could probably do that with the WGA, but why spend $100 on an actuator when you could do the same thing with a $50 manual boost controller.
That's about right. I've figured out that on my Profec B-spec II that the Set % just sets the duty cycle of the Profec's solenoid where 0% bleeds off no air (thereby causing the actuator to open at it's usual 9lbs) and 100% bleeds off as much air as it can from the actuator line, which more or less approximates the action of an MBC. On my 9lb 14b actuator, 40% nets me about 16 lbs of boost.
On a 17lb actuator, even with a boost controller, you can never set the base boost below 17lbs...period. That means you'll need fuel enrichment BEFORE you install the turbo. For a car that's not going to be a 400HP monster, I'd suggest using a lower pressure actuator and a boost controller.
Most diaphragm based actuators will start opening the gate slowly somewhere before the actual boost fully overcomes the spring pressure that's holding it closed, whereas a good boost controller will keep the pressure off the diaphragm until the point you set, then slam it open quickly allowing boost to build up faster.
14.5 drift said:
doesn't it come factory equipped with a 17 lbs spring?
I believe I read the stock actuator is 10lbs and 17lbs is the optional actuator from FP.
I second the motion of getting a good manual boost controller. Last I checked the FP 28 had a 14lb actuator.. Honestly, with decent tuning and the right mods, you can probably eake out 300 and change on the 28.. It's actually a pretty good turbbo for those that want one that is stock appearing. (It's also great for those that plan on running in stock appearing class at the shootout) :thumb:
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
