tial 38mm external wastegate ports - no boost controller
thisdsm
294
Feb 18, 2004
so cal, California
At the moment, I don't have a boost controller, do I leave both ports on the wastegate open or do I connect the side port to a vacuum source from the intake manifold?
Now would that configuration change if I was to acquire a boost controller in the future?
Running the side port to a boost source will let you run whatever the spring pressure is in your wastegate. If/when you are to hook up a MBC you would run one side of the MBC to the side wastegate port and the other side of the MBC to the boost source.
Remember don't let the vacuum lines touch anything. My vacuum line burned off and before i knew it i was running 30lbs of boost
