Tial 35mm external wastegate QUESTION!!!
squeak10686
360
Jul 18, 2004
omaha, Nebraska
hey guys one of my friends has a old tial 35mm external wastegate... with all my stuff ported and the 35mm wastegate do you think i should get boost creep???? its going on a 16g and im going to be running 18 pounds...
I made well over 350whp with the older 35mm my buddy is spraying 100hp shot on 25psi of boost on a 35mm with no creep.
The valve is way large enough for anything shy of 500hp with almost no creep problems. THey only updated to the 38mm gate for either marketing, cosmetic or material reasons, not because the 3mm was a huge difference.
Besides a 38mm gate only has a 35mm opening once the ring is in, and the 35mm is 33mm.
  • Wanted 6 bolt NT water pipe
    • chrisman287
