16g vband O2 housing?
dsmmack
177
6
Nov 7, 2004
Winnipeg, MB, Canada
I've been out of the stock framed turbo stuff for too long, Friend of mine is asking if anyone makes a Vband O2 housing for a 16g?
I picked up a Hahn turbo kit for my Cavalier which uses a Mitsu 16g turbo. What I was wondering if you know of a company that makes a 3 bolt to Vband adapter for the turbine housing?? I cannot use the Hahn downpipe as the turbo needs clocked for use with my turbo header
Anyone know of an off the shelf part?
Thanks.
Seen a lot of stuff but not one for the 16g.
Same here, But wasn't sure if something is out now that I may have never seen in the past.
Looks like an oddball version 16g in terms of missing the bolt hole and the way the gate hole is blocked off.
Probably just better off getting a new O2 housing flange (hoping that its the same lower 3 bolt pattern around the exhaust exit area of the housing) and then just weld a v/band to it.
You could always get a stainless steel vband welded directly to the exhaust housing. I've got a 3'' vband welded to my 16g and it makes it so much easier to take the O2 housing off.
Looks like a normal Hahn super 16g with the 10cm exhaust housing. Same turbo I'm currently running on my setup, also looks like about the same o2 housing I'm running too. Why doesn't he just cut and weld the downpipe to fit were he needs it.
