16 g ?
slowboy racing has a evo3 16G kit. comes with gaskets J pipe, oil return and steel braided oil feed line. Thats what I used to put my 16G on. I also got their SBR manifold. GL
The 16g Install Instruction page found on VFAQ.
Same thing only if you wanna do it on the cheap.
If you're talking about the J-pipe, you can either get a stock one or you can get an aftermarket one. Dejon Powerhouse sells a decent one that replaces the stock soft intercooler hose, and you can get it to go to either a front mount or to your stock sidemount. Also available in a variety of colors. :D
If you're talking about the exhaust flange, it should bolt right up to your manifold. The O2 housing/downpipe combo also bolt right up.
Pics up here would be great. It could be 1 of 3 things. The outlet of the compressor housing in which case like 4lurker4 stated, you would need a j pipe. The turbine housing to manifold, or the turbine housing to o2.
