16 g install
deeeep
110
Feb 24, 2004
tacoma, Washington
so i put a new 16 g on from slowboy and now it makes a whinning noise whin it spools down is that normal and my throttle body makes the same noise please help
its not that loud but it still dose it and it scares me i checked it for shaft play and it only had very little up and down speck is a slight up and down right? and with my throttle body it soundes like the butter fly is viberating ooooooo please help
I Dont Blow Smoke So Im Ok On The Turbo But What About The Throttle Body Is My Butterfly Bad Or Woren
Hey mani just put on my big 16G , and when i let off the throttle i get a quick squeek for
like 2-3 seconds , but im almost 100% sure thats because of the 1st gen bov, what bov do you have now . my t-25 never did it but it wasnt pushing that much air either....
The little squeak is from the 1G BOV. I get it too. Is it a short squeak or whoosh noise or is it a long whine? Based on your description it is too hard to diagnose on the internet as different turbo, BOV, intake pipe, & UIP combinations make different noises. Have you called Slowboy? Not trying to vendor bash but I have seen alot of posts about Slowboy and new turbo problems.
no i havent called slowboy yet but im using a type s bov but what about the throttle body problem know one has had this problem
look over the throttle body see it its closed all the way , you might have to make some adjustments let us know play with it ya know ? open it with the cable from under the hood see if itopens/closes all the way or if its too easy to move :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
