14b in 2G
redturboed95
31
Aug 11, 2004
huntington, West Virginia
hey im on a really tight budget.An i was wondering what i could get out of a 14b on my 95 eclipse gst.with say a rewired 190 fuel pump what could i get out of it.to get the most our of it sould i get a set of injectors and a sacf too. with the injectors i plan on upgrading to a 16g in about 6 months so i don't want to buy injectors twice.Can someone also please give me some idea of what kinda boost i can run and maybe some numbers i can expect to get with it and what i've got now
Get a 2G install kit from RRE at www.roadraceengineering.com
Pick up a 14B and SAFC off ebay or dsmtrader (careful of trader though) You can pick up the AFC for $200 flat and 14B in good working condition for around $150.
Injectors, go with 660s so that you have room to grow. $300.
Rewire the fuel pump with some 10 gauge wire and the car should run much quicker after that. Probably cut some mid/low 14s with much better traps.
heck, you could probably just slap it on for now with the stock injectors for now. rewire the pump maybe.
for installing it, you could drill the holes wider in the oil return and get it to fit. i can't remember if the oil supply line is the same or not. but if you can find a junker at a salvage yard you could use the lines and fittings off there. install kit is just a ripoff to me. main thing you'll have to buy though is a lower i/c pipe to get it to work.
anyway, i had a 95 gsx and threw one on after i blew my stock turbo and noticed a better pull on topend. it'd be good to tune it but make sure you have all the supporting mods as ya get ready to grow to a bigger turbo. blah blah blah. the normal stuff you'll hear. anyway, good luck with it. laters!
scott
  • Wanted 6 bolt NT water pipe
    • chrisman287
