14B in a 2g... Newbie Question
tlcoolj
119
14
Mar 1, 2004
Baton rouge, Louisiana
I just got a good deal on a 14b and wanted to replace my t-25 for the time being. I currently have the following mods:
all the free stuff
K&N intake
2.5" exhaust w/ straight through cat
1G bypass valve
boost gauge & manual boost controller
Once i get the 2g install kit should i go ahead and buy a 190 fuel pump? (I am going with the 190 because i don't plan on going for huge power) Also what would be the ideal boost setting since I don't have an AFCR or should i even install the 14b without one? Any advise is appriciated.
i have a 14b on the stock fuel pump and no fuel control and i can safely boost 15-16psi......you could probably get a way with 17psi on a re-wired 190.
Before you buy an install kit read this: (Some good info for you here)
-14b on a 2g
You don't need an AFCR for a 14b. Your manual boost controller will be fine. I'm thinking maybe you mean AFC.
Thanx,
DeathBeast
thanks for the help... but with the 14b and the 190 in, where would my stock injectors start to max out 17-18 psi??
