14b/16g hybird questions
I believe what you need is a 16g wheel and compressor housing and a 7cm turbine housing to build it at its full potential.
I have new MHI 16G compressors for half that price (PM for more info), but you'll need to machine the center housing a little as well to make sure the 16G wheel has enough backplate clearance. I've seen guys grind a little of the center housing away with a die grinder / cutoff wheel...that's sort-of a hacked way of doing it, but it works.
ok, well thats cool. i sent you a pm
