14 psi to much for stock setup
wishful_laser
242
Nov 25, 2003
springtown, Texas
i just got my mbc today and i put it on. i was only running about 7 psi to start with so i wanted to go for about 14-15psi cause i think i read somewhere on here that i couldnt run no more than that. well, i put it to 14 psi in third gear to get a good reading and when it got to 14 psi i could here some kind of clicking sound from under my hood. i didnt think nothing about. i boosted 14 a little bit until i got to the stop sign and bam. it happened. my car died and wouldnt start back up. i tried the first time and alot of white smoke came out from under the hood.then the next couple of times it came out my exhaust. i can also see what seems to be oil coming out from right below my exhaust manifold.where the manifold and turbo housing meet. im pretty sure i have a blown headgasket cause it was leaking in the first place but i put some stop leak in it and it seemed to fix it. my question to you is, how much boost can my stock setup handle? i have all the free mods done, a k&n filter with a custom made intake, boost gauge and the a pillar.i dont see why my car cant handle 14psi when it is suppose to run 11psi being stock. :confused:
get your new gaskets and do a fuel pump rewire . Goto radio shack to get everything , check out the Vfaq om how-to do it . Then your 14-15 psi will be fine.
Ok ive been looking on the site for over 40 mins now and Im not able to find the guide for the fuel pump rewire, I just see on that says fuel pump rewire kit but there is no pictures or anything. Please link some atricles on how to do this and some other free mods. THANKS :talon:
