14 psi to much
allrice4g63
176
Jun 17, 2008
hager city, Wisconsin
Hi i have a 2g talon tsi automatic transmission with a 14b swap. My question is 14psi to much psi to run on a completely stock setup besides ported 02 housing. Or is that the very limit? another question i had when you rewire a 2g fuel pump will that actually give you more fuel or do you still have to go with bigger injectors and a afpr.
14 psi is pretty good, 15/16 is the max your fuel system can handle. i run my tsi, with the 14b, at 14/15psi
yea i forgot to mention you would need the 1g bov or any other bov than the pos 2g...it looks like your good:thumb:
I ran up to 21 psi on the 14b with just a 255 fuel pump....not saying you should do it but the car ran low 13s @100-102 consistently.
255lph gonna half to get a fpr,Then a manual boost controller,But you will be able to boost higher without hitting fuel cut,Very easy setup for a little extra power.
But a stock 14b at 14psi is good for a dd,Still will give a good amount of power.
