13g to 14b swap
slidewayzka
Jul 2, 2006
American Fork, Utah
so i decided to swap out the stock 13g turbo for a 14b, i thought it was a straight forward swap but while doing it i realize that the water drain pipe is different between the two am i right or is the difference in the size of the banjo bolt? will the water drain pipe from a 2g work?
also the 13g manifold is smaller so the alignment ring for the 14b wont fit with the 13g manifold but im ok to go without it ive read. im ordering a new manifold and o2 housing but i need to get my car back running until my next payday.
i also read to use the 1g 5sp ecu, 450 injectors, FPR, and cams correct? so the 5sp. ecu will work on an automatic? anything else im missing?
also on the 1g ecu which ecu pin is the air/fuel so i can wire up my apexi timer and gauge. thanks
Both waterlines are different on the 13g. Be sure to change that manifold as quick as possible. If you car is automatic be sure to get 450cc or higher injectors as 1g autos came with 390's.
