13g to 14b
speedracer91
281
Jul 10, 2004
Rockford, Michigan
hey it's time to upgrade my turbo. Right now i have a 13g :barf: (i drive a 91 TSi AWD auto...) and i'm looking into buying this one 14b. What do i need (if anything) i'm guessing o2 housing....also will the 14b bolt right up to my exh. mani.?
thanks in advance :thumb:
When I upgraded to a 14B, I got new water/oil lines, 2G exhaust manifold, and a few other mods. I know you need a new manifold.
well i was planning on getting a ss oil line and new water lines....will my o2 housing still work? thanks again :talon:
*edit* will the 2g exhaust mani. blot right up to the 14b?
2G exhaust mani is perfect for the 14B. The O2 housing is the same for both turbos IIRC.
You do need new oil and water feed lines, copper crush washers and banjo bolts. The 13G hardware is too small. The water and oil return lines fit just fine, but you'll want a new gasket for the oil return line.
The best idea would be to talk to someone that is upgrading their 14B to a T3/T4 or TD06 turbo.
They need new oil and coolant lines, as well as a new J pipe and often, their exhaust manifold gets changed too (if going T3).
I've seen guys sell their good 14B, O2, J, oil and coolant lines for like $200.
i was planning on running 10 pis for 500 miles than up to 14-15 psi...is anyone upgrading to a t3/t4 set-up.... ;)
