11.3@131 eclipse
Am I losing it or is that a down hill track? Irregardless, nice run and good luck on getting into the tens.
Part of the end definitely "looks" down hill to me.
What was your 60ft? I bet if you improve the launch you will hit 10's with no other changes, slip the clutch some to keep it from spinning the whole way through first.
On that run it was 1.744. I got 1.685 on another run. This was a cold day and I'm gonna do my best to get into 10's next saturday.
Very nice! A little bit better track and 10's! About a month and a half ago I went 11.1 @ 129mph with my holset powered 1gb talon. Hopefully going to the track soon in a quest for 10's as well! Keep it up!
Thank you and good luck to you as well.
What holset are you runing? Boost and what gas?
hx40 pro with the .55 a/r bep housing, 29-30psi on e85 with only like 16 degrees peak timing, stock intake and tb and BC 272's....
I am hopefully going to the track this sunday in a quest for 10's!
