1 bolt rear main seal?
FastGS-T
295
8
Oct 20, 2005
Arab, Alabama
Well I was finishing up my 6-bolt build today (im a 1st timer so its taken me a while). But when I went to put on my rear main seal I was going to get the bolts from my old 7 bolt rear main seal (my 7 bolt motor had a million things happen at once)
Anyways my 7bolt's rear main seal was only held on by 1 bolt and no gasket. Would that have leaked like niagra falls, enough to cause some of my engine problems i had?
blackGSX2g said:
There is a circular seal that goes around the rear crank snout, and the assembly is held in by 5 small bolts. Slowboy Racing sells both the bolts and the seal.
You didnt answer his question. Just just stated something that is already obvious to him.
Yes, it will cause a major leak if there is no gasket or sealant and 4 bolts missing. I dont know what other problems you had so I dont know if this was the cause to them.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
