1.8 timing
tunerangel
91
Aug 15, 2009
Winnsboro, Texas
Hello can anyone help me on telling me or giving me a link to where i can see where the 1.8 motor timing marks are. thanks.
can someone please help?
1-Cam sprocket has a dimple that meets up with the vertical groove on the cam cover retainer bracket.
2-Front balancer sprocket has respective marks both on sprocket and block that needs to be aligned up.
3-Rear sprocket, being both the oil pump and rear balancer shaft also has their respective marks. BUT, this sprocket has to be "in phase" with the crank, or serious vibrations will result. To check "in phase" is to rotate this sprocket til the two marks align up. Release the sprocket. If the sprocket rolls clockwise, it's 180* out of phase. Rotate the sprocket again to the marks then release. If the sprocket then rolls anti-clockwise, it's in phase with the crank. then align the marks up to meet each other.
4-Crank has it's respective mark on the belt sprocket and block.
5-You get the front balancer belt installed first with the crank sprocket and balancer sprocket aligned then adust the tensioner pulley where you have a quarter inch deflection then tighten down the bolt.
6-Put main belt on cam sprocket and clip it down so you can lace the belt over the other two sprockets - making sure that the marks align up perfectly at all times - no margin for error allowed.
7-Adjust the tensioner pulley to where you have, once again, the quarter-inch deflection on the long side of the belt then tighten down the tensioner pulley.
Good luck - DSM
