tech27
- 0
- Nov 9, 2005
saint joe,
Missouri
hello I recently bought a hyundai with a 1.8 dohc( mitsu motor) to drive I own a 93 laser20 turbo but anyways back to myquestion after driving it home I noticied a timing belt squeal so i pulled the belt cover and found the balance shaft belt was broke I replaced it and now when i start the car it has a loud knocking sound coming from the crank area I have checked and rechecked the timing marks and after turning it over by hand six times all the marks line up dead on can anyone help:
1. bought car
2. heard belt squeel from timing belt area
3. found balance shaft belt broke
4. after installing belts hearing a knocking sound from crank area changes with engine rpm
5. double checked timing after six revolutiuons of crank all timing marks line up
94 hyundai 1.8 dohc
(mitsu motor) with auto tranny
can anyone help
thanks
1. bought car
94 hyundai 1.8 dohc
(mitsu motor) with auto trannycan anyone help
thanks
ne of the two bearings it spins on, is probably working it's way out of it's location.Sounds like a rod knock, right.You can remove the belt and leave it off if you also re move the rear balance shaft and replace it with part #MD098626 oil pump drive shaft.You leave the front shaft in place so long as your 2 bearings are still in place.If they have spun out of place,you have to install new ones.If you want to keep your balance shafts,line uo the oil holes.If you want to remove your shafts misalign the oil holes.If the block won't accept new bearings because of damage from the bearings spinning out,you're screwed.
