'07 STPR Race Report
outofideas327
36
Dec 30, 2003
North canton, Ohio
The first weekend in June was the Susquehannock Trail Pro Rally in Wellsboro PA. STPR is the 5th national Rally-America event of the 2007 season and brought just over 50 entries to the fast and unforgiving logging roads of Tioga County. Dave Johnson and I were crewing for the Don Jacobs Subaru/ NunneMonster Racing #686 PGT WRX, occupied by driver Heath Nunnemacher and co-driver Heidi Nunnemacher. STPR is a tough rally, mostly due to the high speeds, close trees, and a clay base that when wet is quite slick. What the whole team needs is the most service experience/seat time possible, therefore the goal was to run smooth and finish.
Friday morning we headed out to tech at the airport. A set of lightly used Hankooks and the light pods were thrown on then we took the car through tech. After tightening up the seats a bit, and mounting some new, stiffer roll cage padding the car was signed off. We then picked up our barrel of 104 unleaded from the fuel supplier. Back to the house to change the gearbox fluid and it was on to the practice stage. Checked the gearbox fluid again after the drive to the stage and found it was overfilled. I attempted to drain a small amount, but when the hot fluid hit my arm I dropped the drain plug and lost all the fresh lube :coy: . Luckily Heath had a 5-gallon bucket of fluid, so we refilled the trans, mounted a set of fresh Hankooks and finally got the car down and let it go to the practice stage. They ran the stage a couple of times and came back in. The report: car was SLOW. Checked the wastegate, vacuum lines, throttle linkage, pulled the intercooler to look for ripped couplers, hoses, and found nothing. We closed the hood without a proper diagnosis, and attributed the power-loss to the hot ambient air and possibly a flaky O2 sensor. While the car was still up on stands we tossed on a new set of front rotors/pads as it poured on us (which officially made it STPR). The rest of the night was spent at the pizza shop and movie theatre.
Saturday morning we showed up at The Green around 9:30am for Park Expose. “The Green” is the center of the small town of Wellsboro. There was quite a large crowed spread throughout the town that morning, which is always great to see. At that point I grabbed my camera and got some pictures while the cars were still all in one piece, and watched the cars roll out. First service was 15min at the airport, after running three stages. A quick check through the car, refuel and re-attaching a corner of a skidplate, then it was back out to run SS4 (Subaru Splash) followed by another service. Heath and Heidi were running clean, which kept this service simple. The brakes were checked thoroughly for any damage from the creek crossing, and everything looked up to par. After that everyone had a lunch break/park expose #2 back at the green. We wired up the new fog lights, and attached the upper light pods equipped with some new PIAA HID’s (what a difference!). Cars left the green again to start the night stages. Then hurry up and wait at Germania for the 45min service. Here's some pictures from Park Expose and service:
The crowd:
The new Coralba rally computer:
From www.flatovercrest.com
I sat at the truck listening to net control while holding an entry list. I must have crossed out about 7-8 cars who had DNF’d before the leaders started trickling into service at about 9:00pm. There were lots of delays, so we decided setting up the generator and lights was a smart thing to do. When Heath arrived at Germania service, we found out that the fuel supplied at the event was actually 110 leaded instead of 104 unleaded! Not good for our O2 sensors or cat. Nothing like having 55 gallons of the wrong fuel, but at least we had an answer for the power loss. Once ‘checked in’ to service we began work on the car. After tightening the shock mount bolts up in the rear, I noticed the front left rotor had a big ‘ole crack in it, most likely an after-effect of the water crossing. I changed the rotor out with a spare while Dave went through the rest of the car. We finished up with time to spare and watched as car 686 went on to start the last leg of stages at 10:15ish.
After packing up at service it was back to the airport to wait at the finish. Pancakes, eggs, and juice were provided in one of the hangers, which helped to pass the time. After watching Pinker, Ramana, and Pastrana do their champagne spray (~1:30am) we starting looking for our car to roll in. The car that started behind us came in, but no sign of Heath and Heidi. A couple more cars come in, and then more, and more. Eventually Dave finds out that one of the teams saw #686 on its roof on the last stage but everyone was ok. While frantically trying to find out where they are and if they need us to fetch them, around the corner they came, what a relief. They had got the car flipped back over, and were able to continue on (although the ~20min lost put us last in our class). At ~2:00am the Nunnemachers checked in at the airport, and we had officially finished the rally.
At least 15 cars DNF’d, so just to finish was an accomplishment. We ran towards the back of the PGT pack throughout the day, mostly due to the fact that the car was making no power. Apparently off the start line and exiting hairpins the car was just horribly slow. Times from SS5 show a lot of potential, and there is much to improve upon throughout the team, especially in service since Subaru’s our fairly new to me. Huge thanks to Tom and the rest of Hanson’s crew who have given us a hand on several occasions. As for the car damage, the roof will need replaced and the driver rear fender is pretty banged up, but not too bad. Here are the overall results:http://www.rally-america.com/event.STPR.2007.php?section=results_overall You can also look at each stage individually. More pictures below.
-Chris
Car #523 Travis and Terry Hanson:
Ford Escort Cosworth...gotta love that sound.
Yes, the Rally-America series will be on ESPN2!
Overall winner Andrew Pinker and Robbie Durant:
Service at the airport:
AWD Turbo Hyundai Tiburon of Paul Choiniere and Jeff Becker, 4th overall.
Seamus Burke was seen doing well over 100mph on this rim. Finished 5th overall:
Damage done by the flat:
Top 3- Pinker, Ramana, Pastrana
Amazing pics and story! I felt like I was there!
I really wanted to make the trip out to PA to see another rally this year, but I have been really busy helping my brother in law remodel his house. I went to Sno Drift in Jan. and it was a blast, but damn cold. I would like to see a rally in warmer conditions too.
Thanks!
Jeff
EDIT--- Oh yeah, how did that DSM do? Car #533
Was 533 the only DSM?
Are DSMs still competitive? (They used to dominate their class until Evos came along)
What class are DSMs in these days, and what do they run against in that class?
Rich
#533 of the Ritchie brothers finished 7th in the regional rally. There were 2 dsm's and 1 Galant vr-4 (which is now for sale, somebody step up!).
AWD DSM's can run in Open or Production GT (PGT). Being competitive in PGT would be possible with the right driver. In PGT you'll be running against mostly wrx's. Open would be tough, but building an open class car would be a lot more fun. Heck, Doug Shepherd (Rich you might recognize the name) drove to 8th overall last year when he brought out his outdated open class dsm, and supposedly he wasn't pushing.
Black95tsi and Jeff, thanks for the comments. Jeff, it looks like the closest warmer rally would be 100aw, or LSPR , although neither are "close". Another option would be Rally West-Virginia put on by NASA. I should be down there either spectating, crewing or (hopefully) co-driving for the first time.
I was, at one time, King of loose gravel.
Rich,
I think your success in road racing in such a short amount of time is proof of the above statement. Come back to rally, even if it's just a couple regional events a year. If you're lucky, you'll be as fast as these two! ;)
You could always build another 510, or some other form of a proper (rwd) rally car, and enter the Max-Attack series. Max-Attack is for 2wd only, and offers pay-outs for 3 separate rallies.
-Chris
Rich,
-Chris
Thanks for looking up that photo. Alas, that's not our car--ours was a two-door. Otherwise, it was identical.
If anybody is really bored, and wants to read about our dreary rally experiences, go to
http://www.specialstage.com/forums/showthread.php?p=191786
I managed to dredge up memories in a series of posts. I just rambled on and on...I hope I got across the message that rallying is ten times more exciting than road racing. There is no comparison to running 100 mph on black ice, with a car one minute behind you.
*sigh* Nostalgia just isn't what it used to be.
Rich
Rich,
-Chris
Thanks Chris, I didn't even know NASA had any rally events at all.
I will have to check that out. Might see you down there! WV is not all that far from me.
Another interesting story from STPR:
During the practice stage on Friday Ken Block pretty well destroyed the back half of his car. (pic) The team had a spare car brought out from Vermont and re-prepped it all through the night for the start on Saturday. Alex Gelsomino, Ken's co-driver, had a minor concussion from the wreck and was advised to sit out the rest of the event. In his place sat John Buffum (US rally icon), or according to the name on the car...Sack of Potatoes.
From Andrew Harvey at www.flatovercrest.com
STPR will be on ESPN2 TODAY at 5:00EST. It's an hour long show that includes 2 other rallies as well, if you have the chance make sure to watch! This will be a great one to see because of the extremely close battles. Post up any opinions if you do catch it!
Chris
Rich
I believe the short answer is no. Though very reliable/durable once sorted out, the DSM is out-handled and often out-powered by the WRX due to the new PGT rules. Parts support continues to dwindle as well. The Sno-Drift Pro-rally is one of the few places where DSMs can still overall podium (more dependent on driver).
-Dave
#532
