02 sensor identification??
bigbrdf250
59
Dec 9, 2011
SugarLand, Texas
How do I know what a upstream or downstream 02 sensor is. I know up is first from the mani but cannot tell on my set up. I have a aftermarket housing and its got 2 o2 bungs. One is the wide band and the other a factory sensor. Looks like they all scavenge in the same way after the turbo. Is this right??
I need a factory plug and play to make it easier for me. Thanks.
Well, a downstream sensor is typically downstream :)aha:) from the turbo. In the case of factory sensors, only 2g's have a downstream sensor which checks for a functioning cat only. Both 1g and 2g have upstream o2 sensors (which sit in the o2 housing) and send the ECU a signal which it uses for fuel trims.
