2G 2G FWD Fuel Filler Hose Replacement
kyler021
213
165
Aug 29, 2023
Pasadena, Maryland
Hey all,
My fuel filler hose has started to leak because of this cold weather. Does anyone know of a replacement fuel filler hose for a FWD gas tank and filler neck? I have seen the AWD replacement, but I have yet to find anyone who has confirmed fitment on a FWD.
I was thinking of just ordering the AWD version and hoping that worked. The hoses in the AWD and FWD diagrams look to be the same but they have different part numbers. The one that works for the AWD is the Spectra Premium FNH121. Would anyone be able to help me out here before I order that hose? Thanks!
The Awd and Fwd flexible is different but the metal hose is almost the same. Depends on 98-99 models.
The AWD had a dual sized hose from neck to tank while the Fwd is the same from neck to tank.
I awd swapped my 97 gst and as such, I have a fwd hose on my awd tank. It was a slight pain to get on the tank nipple but it's been fine. So going with the opposite setup, like you're talking, double hose clamps might work to clamp it good enough if you can find a hose cheap enough to at least try it. Or if you can find the perfect size T bolt clamp, that should work.
Ahhh I gotcha. Thank you for the info! I wonder if I could try double clamping the wider side or something like that to get it to work on a FWD tank.
Perfect! I actually have a t bolt clamp from my second FWD fuel tank so hopefully that can work! Thank you for the insight!
I'll leave this post open until I order the hose mentioned in post 1 just in case there's a hose out there that I'm missing. Thanks everyone for the replies!
My 99 FWD fuel filler neck was so rusted it leaked thru many pin holes . The fuel filler neck 98-99 - Spectra FN906 fit perfectly.
Sorry, I meant this hose. The rubber fuel hose that connects the filler neck to the tank. I was not happy when I wrote that new message ROFL. Context would be helpful I guess LOL.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
