1G Searching for a Flywheel for a Non-Turbo 2.0 litre on my 1991 Talon
666872729107
2
Jun 4, 2026
Richmond, Illinois
Hello DSM fans! I have a '91 Talon (Base... or ES in '92) with a 2.0 Non-Turbo, 5-speed, FWD.
I purchased this car NEW over 35 years ago. STILL LOVE the car, It's in terrific condition, always garaged, no rust, runs great, and still looks very good! A few mods, nothing major... with hopes to do more. It is in need of a NEW timing belt and clutch. I have ALL or MOST of the parts, but having difficulty finding a NEW Flywheel, as I think it's best to replace the flywheel at this point. The engine has about 90k mileage on it. This is the 2nd timing belt (Just want to replace for safe measures) but clutch is going out. I JUST CANNOT find a NEW FLYWHEEL ANYWHERE FOR THIS APPLICATION! ALL I find are ONLY for the Turbo 2.0. I would NOT mind finding a Performance Flywheel to replace it with, but I want one to be the direct replacement and not one that will not work with the 2.0 Non-Turbo.
Does anyone have a good source or suggestion? I found a place online for a Used flywheel for $285. Would rather have NEW, and maybe with better performance (If needed or rather possible). IF not, that's fine too. THANK YOU!
Nice looking 1g!
Is that a 6-bolt flat faced flywheel, like this one? https://www.ebay.com/itm/316141485849
New OEM is like bigfoot. Supposedly there's old stock out there somewhere but you'll never find it.
I don't have any info for an aftermarket version. That's not to say it doesn't exist.
Have you considered machining your current one?
While I understand the desire to have fresh new parts you should verify that you need a new flywheel. Usually they just get resurfaced unless the starter teeth are chewed up of the surface is all heat cracked. I'm assuming this is the original clutch and that the flywheel hasn't been resurfaces a few times already.
I got about 100k on my original clutch and they just refreshed the surface and step (don't remember if the NA 2.0 has a step) when it was replaced.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
