So what are you working on that’s NOT your DSM?
Wife's Prelude was showing cords on the front tires when i replaced the strut a fee weeks ago. Got a set of GMaxs, but id be putting them on some wheels that are in desperate need of reconditioning.... So decided to try painting them. I know i should powdercoat them, but car isnt driven in bad weather and sits in the garage all week so should last long enough. Have been doing a little sanding everyday since work is so bizzy. Should be ready for primer/paint this weekend.
Finished refinishing the Prelude wheels and got the tires mounted and balanced. Not perfect, but turned out great for a first time. Wife was super happy with it. VHT Ford Argent color was a perfect match, 2k clear...I only polished the center caps instead of painting them and everything matched. Went to get an alignment and found out she needs 4 new control arms. 2 of which arm discontinued with no aftermarket suppliers 😕 so guess im going to have to track down some prothanes.
Had to replace the internal shifter in a Mule 4010 Diesel transmission. Replacing the part was easy work but reinstalling the transmission and axle assembly will be the hard part.
No I didn't use the proper jig and yes the Harbor Freight lift held the transmission perfectly level. If I bought the proper transmission tools everytime I wouldn't have any space left. It's normally work with what you have.
Sold my buddy this wheel for his RHD S14 and he wanted to be sure the horns worked so I had to make that happen. Unfortunately he didn’t buy a quick release yet so the wheel is super close to his stalks but it’s on!
If you've never been bit by the horn wire, be aware, it can and will sting. 😉
I have a 1984 V45 Magna but no pictures and the carbs are off currently. It's a cool and fast old bike plus it has the 6th gear for economy. King/Queen seat from a V65 and a small windshield. Shaft drive and water cooled. Very comfy but I no longer trust John Q Public to see me, so that's why it hasn't had the carbs put back on. I don't trust the roads anymore. Its Dark Blue and has that small rake to it, like back in the day. I'll see if I can find any pictures of it.
This is a V65 but is the same frame just bigger engine. 😊 ✌️
2 stroke fan here!!
If they ain't smokin', they're broken!! :cool:
75 RD350 (orange) and 73 CT3 175 (gold) both up and running with clean carbs and fresh fuel.
I "ALSO" have a 1974 Suzuki TS185. It has a stuck clutch at the moment and I'm not real good with motorcycles.
It looks just like the owners manual shows in color. It needs a battery too. 🫤
^^^ That Zuki 185 is an awesome bike!!! :thumb:
The Yamaha 175 above had the same thing going on with the clutch; bike was parked in 1980 with 1200mi on it.
I woke it back up a couple years ago to discover the clutch didn't want to release very well (or go into Neutral while running) and it slipped at the top RPM range in the upper gears.
Installed new friction plates, re-used steels, re-used springs and a fresh oil change; shifts like a 70's Japanese bike again!
The frictions I removed; I couldn't tell you why they were the cause of the problem by looking at them. So theres that!
Looks clean Brother
Thank you for the tips! 👍
Good idea Jason. I recently made a tool too, but far less fancy and just to save me a drive to the tool store LOL
My buddies new to him 04 anniversary, 55k one owner, Kenne Bell 2.1 and full Maximum Motorsports suspension kitted and corner balanced Mustang. It is a well done car with a binder of everything done since new. Probably a $50k build. $10.5k is a steal I think. What do you all think? We were going to look at a 2008 Roush but that guy didn’t message him back and he started showing me this. Why are we going to look at that other car now?
Next a 2002 in for upholstery work next door.
Finally a 94 850 with 58k. Recent full paint and maintenance done for a sentimental value to the new to us customer. If you haven’t reset dash lights in the old Volvos it’s a trip. There’s a box in the engine bay with a pin. Insert pin into 1 of 12-13 holes and do a sort of Morse code in sequence.
