My other daily driver!
My old 95 Talon resurrected. Every single nut, bolt, wire, and glass from my wrecked talon ported over to another unicorn early 95 model GSX shell.
Summer is wrapping up in the south, but these storms sure haven’t slowed down. Let’s be honest, these wipers stink. I needed a better solution. Well I am here to tell you, nothing is better than oem Honda wiper blades. And bonus, you can replace the rubber later for $5-10. After a little back and forth I found these are the length we need:
22”
2012 Honda Civic Coupe: Honda 76630-TS8-A02 Windshield Wiper Blade 2012-2015 Civic New, Genuine
16” 425mm​
76630-SV4-A02
Now, these will bolt on, but they aero will be backwards. So, get your flat head screw driver and flip the part that attaches to the wiper arm. Then they fit perfectly and work absolutely squeak free! And like I said, refills are dirt cheap from Amazon.
Very nice work!
Can you tell me the AC pulley bearing number? (not the MB878243, the bearing number is what i need) im going for a koyo if i found some...
Finally found some time to build my third version of headlights. This time with far superior Morimoto Bi-Led 2.0 projectors.
Old (closer) vs New (further)
Part 1: How to retrofit a 97-99 Eclipse headlight with a Morimoto Bi-Led 2.0 Projector
Output is incredible!
July 24: sent my seatbelts out for replacement. Few days later and like brand new. They retract now automatically which was a welcome change. Cannot recommend enough. Safetyrestore.com
Good to know !!
June 25: sent the 2g rear lsd oem axles off to a local shop in Bufford GA. Turns out the owner Jon loves our cars and knew literally everything about our axles. After souring him another axle with a good inner cup, he completely rebuilt and reassembled to oem. I cannot recommend cv source enough!!! He only works on oem but trust me, go there.
Like new!!!
Same !!
Great thread 🧵 !
hey, can u tell me the bearing code for the ac pulley? thanks!
Where did you find the alignment tool/jig for drilling the holes to mount the projectors? I've had zero luck finding them anywhere online.
Google “mounting plate retrofit tool.” I want to say I dropped $100 on it. I do a lot of retrofits for friends and family so sort of bit the bullet once
This is a go right now and buy mod you should absolutely do this weekend! Use your oem 2g foglight as a base to adapt/mount a brand new 70mm morimoto fog light. The output is absolutely bonkers and it only takes about 20mins a light, start to finish.
97-99 DSM 70mm Morimoto LED Retrofit
One morimoto, one oem 2g, and no headlights on!
