XTD clutch problem?
dmc67
290
3
Oct 17, 2004
Middlebourne, West Virginia
ok when I tighten up the Pressure Plate it gets really really close to the clutch disk springs. I got the Stage 1. It might just be my imagination but something isn't right in my clutch system, clutch pedal grabs right off the florr dont seem to have any pressure at all and I got the rod adjusted as much as possible changed the reservoir and Slave Cylinder. the PP fingers are so close to the clutch disk i can barely get a small screw driver in between them.
Any help would be appreciated.
http://cgi.ebay.com/ebaymotors/ws/e...d=1,1&item=8037228750&sspagename=STRK:MEWN:IT
the disc facing the rights way?the big hub on the disc goes towards the engine.
Are you possitive that the hub on the clutch disk goes toward the motor? On my N/T the flat part was facing the flywheel.
yea your right,i checked.sounds like you need to bleed the system.i had a similiar problem,and thats what it was.
ok i thought i had it right. I bled the system for quite a while with no luck. I got another tranny to try b/c i think the syncroes were out of the other one.
