tkstoygsx
- 190
- 1
- Dec 9, 2007
Green Valley,
Illinois
So after fighting with setting all my sensors and boost leak testing about a hundred times i have discovered that the throttle body i received and installed is sticking. holding the throttle plate open about 1/8 inch and the spring is not able to pull shut. Reason must be due to a sticking throttle plate. Was not doing so before the install but i think now due to the heating and cooling from being installed this has occured.
have any of you other DSMers ever received a throttle body from this company and had troubles with it?
I purchased the 65mm throttle body with half shaft mod.
I dont know if it will be easier just to fix myself with a little sand paper or try to send it back for a refund or new one.
please respond with feedback.
thanks
thanks
