greekgodchaos
- 565
- 213
- Jul 4, 2007
Vancouver,
Washington
1991 Eagle Talon TSi AWD M/T W5M33 23 Spline
Okay so here is the back story: I rebuilt my transmission with basically all the same parts but cleaned up, and everything was fine until about 2 days ago where I was at a stop light, shifted into 1st and then moved forward, I go to shift to 2nd and 1st was just LOCKED in place, it took both hands and some grunting in order to move it into 2nd, this terrified me so I went to my friends place and long story short;
1st and 2nd = No Movement, and a SH*T ton of grinding.
3-4-5-R = Movement.
Then I had to drive 18miles using 3rd gear as my "1st", which cooked my clutch disc. So this morning I began tearing everything apart in order to remove and dismantle the transmission.
Then I came across this:
Would this bolt (interlock plate bolt) being loose cause the same symptoms of having a busted 1-2 fork? I mean this bolt was LOOSE, mainly because of my BS Delete and Drilled Prothane Motor Mounts, I have been loosing any and all bolts that didn't have lock washers on them, and I am finding that I have lost at least 10 bolts in separate areas because of the damn vibrations.
Here is another picture of it, courtesy of Dre's rebuild manual:
When I had the transmission apart the first time, I noticed that without this bolt, shifting from 1-2 into 3-4 was nearly impossible since the plate wasn't being held in place like it should to keep the rails straight. Also earlier I was able to move the shift linkage ends (on the transmission itself) into all gears no problem, but that's likely because the car was off. Any suggestions at this point? Should I just continue and drop the transmission? I have to anyways to replace the clutch disc with my 6-puck, but between me and my dad, we have 4 cars and are now down to 1. I am seriously hating my car at this point since I could go either way with this
So now here is where I am at:
*The bolt is tightened up now
*I can use the shift levers on the transmission to select every gear
*The transfer case is OFF
*The transmission is DRAINED
*The linkages are OFF (I also found out, for whatever reason, I have 2g linkages)
*The clutch needs to be replaced since it will probably fail soon if I don't.
I will still pull the transmission and most likely tear it apart, but if I only have to replace the clutch that would be so much better. I didn't see any metal chunks in the fluid, just some very fine metal shavings (from the stupid amount of grinding no doubt)...UGH does anyone have any helpful insight into this??
UPDATE: Found this bolt ("Restrict Ball Assembly") Was about 3/4 backed out, here is a picture:
3-4-5-R = Movement.
So I am sort of trapped within a 5 mile biking radius
