bo0st2
- 237
- 50
- Dec 25, 2023
Arizona
If anyone is familar with Sparco seat installation I could use your help
I got a Sparco R100 seat on the way, looking to install it on the driver side in the 2G DSM since the current seat is just torn up too bad
The seat will end up looking like this:
I know I need brackets, does this bracket below look right?
I found it here:
Besides that I also assume I need these sliders right & some bolts ExtremePSI has those
From
Is there anything I'm missing for a good clean smooth install? I'm going to want full adjustability of the seat.
Also can I use the stock seatbelt or do I need a harness?
Thanks in advance!
I found it here:
Code:
https://www.evasivemotorsports.com/store/product/sparco-seat-base-600-series-mitsubishi-eclipse-95-99-driver/Besides that I also assume I need these sliders right & some bolts ExtremePSI has those
From
Code:
https://www.extremepsi.com/store/Sparco-Adjustable-Seat-Sliders-Track-Set-Universal.htmlIs there anything I'm missing for a good clean smooth install? I'm going to want full adjustability of the seat.
Thanks in advance!
