WOT switch on TPS??
v8what
Apr 1, 2006
Tri-Cities, Washington
Anybody know which wire is the full throttle switch on the throttle position sensor? I have a '95 gsx and I'm bottle feeding it. I can't seem to find any info here or online. :confused: The TPS has 4 wires:
brown/red
grey/yellow
yellow/red
black
Please only help if you're sure. thanks
brown/red
grey/yellow
yellow/red
black
There isn't a WOT switch on/in the TPS. There is a idle switch on pin 3,
For future reference from the FSM:
2G 4G63T TPS
1 - Green/Yellow (+5v Sensor Power)
2 - Brown/Red (TPS output voltage)
3 - Yellow/Red (IPS switch)
4 - Black (Ground)
1G 4G63T TPS
1 - Green/Red (+5v Sensor Power)
2 - Green/White (TPS output voltage)
3 - NC (IPS is on the throttle body using a green wire)
4 - Green/Black (Ground)
Steve
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
