wot in high gear car studders around 3k rpms-4k rpms
pOlAkGSX
Sep 27, 2003
when i hit full boost at wot on the highway lets say in 5th gear, my car will studder almost like its hitting fuel cut, i dont know whats goin on so if anyone can help let me know, my car is a 2g gsx, i have a 3"turbo back exhaust, dejon tool 2.75" intake. profec b 2 boost controller, safc2, walbro 255, magnecor 8.5's, and 2.5 inch upper ic pipes. if anyone can help me out that would be great. this happens when boost is around 13-15 psi, and this never happens in 1st or second and it never happens when out of the 3k-4k rpm range.
thanx
pete
Have you checked to make sure your spark plugs/wires are good? Might want to swap those iridium spark plugs for some regular NGKs. When was the last time you replaced your fuel filter? Do you have a datalogger for your car?
this was goin on in my 91 tsi as well i found that my reg ngk were running to hot and had to go with a 7 or 8 what i mean by 7 or 8 is the part number for the plug its like bpr6 something like that i got the bpr7someting and the seemed to correct the problem
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
