Wiring Harness question
MU801823 22 pin ecu plug (2x11)
MU801822 16 Pin ecu plug (2x8)
MU801824 26 Pin ecu plug (2x13)
MU801820 12 Pin ecu plug (2x6)
that are the mitsubishi plug repair plug numbers for the evo 8 ecu, the fit in 2g ecu's also.
If you just need the connector housings, i don't know.
Its great to have the part numbers, but a few simple searches through google and yahoo found no hits for the part numbers. Would i have to go to a Mitsi dealer to get this or is there a site on the web. Ive been searching for a while, my lack of knowledge of the technical names for the part is making i hard to find through simple searches.
You have to go to your dealer. The part numbers are from the evo 8 manual. and don't let tell you, they don't have them, they can order them.
This are us part numbers, i orderd them from germany, i had much trouble to get them because of the us part numbers.
Im starting to think this might be more trouble then its worth. i was wanting to make a PnP harness that has the wires pre-switched for an EVO 8 ecu with a Safc pre-wired in and a fitting for an Air/Fuel gauge. I believe those connectors cant be to expensive, at least i would think, and Im sure it would lead to a cleaner install.
