Wiring harness question.
talonation777
200
Nov 15, 2005
Niagara,
I'm in the process of wiring my fog lights for my 2gb conversion. I know a guy who has the factory wiring harness, my question is, how difficult is it to remove the harness from his car, and hook it up into mine? Does is just simply unplug from under the fuse box, or is it more elaborate then that? Thanks in advance.
It's part of the front wiring harness and NT has a different harness than turbo.
What - you aren't going to wire it yourself even after I showed you how in your other thread (http://www.dsmtuners.com/forums/showthread.php?p=151217161#post151217161)? I think it would be easier than swapping harnesses especially since the harness to the dash for the fog light switch may also be different. Or are you thinking of ripping out the fog light wires from both harnesses? You'd still be better off wiring it yourself. And you can put the relay anywhere - (even right in the same spot in the engine fusebox as the factory one if you want).
Wiring it myself was my first choice, but when I saw a guy who had a harness, I thought it would be easier then wiring it up myself.
My wiring/electrical skills are limited, I haven't done much wiring in my day, so with that said, the diagram you provided me with may be helpful to those who understand it, but for me there are a lot of things I don't understand. If you can elaborate further on the diagram, perhaps putting it in layman's terms. Thanks
Here is a fog light diagram that shows the typical relay most people use (with it's correct pin numbers) as well as how to hook into the hi/lo dimmer passing switch if desired. All parts are available at any auto store or Home Depot.
