1G wiring fans on all time
Jon_0_3
164
Jul 5, 2004
Hartford, Wisconsin
i am having a problem with my fans and was wondering if there was a way to wire my fans so when i tern on my car the run at all time
Yea, I just put a paper clip jumper in the fuse box where the relay is. I can take a photo later tonight and put it up for you.
I had used one of those large black office style paper clips and just cut the handle. But anything would work as long as it is thick enough to make contact with the connections.
I just took my AC out and use the AC button to control when i want to run my fans, which is always. Good idea on the paperclip.
I ran a wire from the cooling fan plug in harness ( a blue and red wire ) to the inside fuse box on the ignition fuse in which my fans are always on once the ignition is on ( both fans will come on once you do this. You only have to splice into the red/blue wire on the cooling fan . ) Its been like this for over a yr with no problems, and its always on high soon as the ignition hits, why wait for it to warm up to turn on?. . . Just dont sit with the ign on and the car not running or the fans will kill your battery.
just like nightspeed87 said, the fans are on all the time. The thermostat is what controls the temps in your engine. with this you are only cooling the radiator. Its funny to watch my temp guage come up to temp, I have a 180 degree. When it opens and lets the radiator fluid in you can watch the temps needle go down about 7 degree.
